Highlighted
Aruba Ansible github is public now!!
https://github.com/aruba/aruba_switch_ansible
Checkout modules, workflows like configuration of switches, ZTP, firmware upgrade and much more. There is also a different branch on taking this code and running it from Ansible Tower.
ROB HAVILAND
SR. DIRECTOR TME, ARUBA WIRED INTELLIGENT EDGE
CAMPUS / DATA CENTER
M: 414.841.3605 | rob.a.haviland@hpe.com
8000 FOOTHILLS BLVD | ROSEVILLE, CA 95747 USA
Highlighted
Re: Aruba Ansible github is public now!!
Is there any ansible modules for Clearpass and in general for wifi devices?
Highlighted
Moderator
Nothing for ClearPass. Can you please provide details about what you're looking for?
Ansible orchestration doesn't really apply to ClearPass.
| Tim Cappalli | Aruba Security | @timcappalli | timcappalli.me |
NOTE: Answers and views expressed by me on this forum are my own and not necessarily the position of Aruba or Hewlett Packard Enterprise.
Highlighted
Basically , I am able to configure all my network related stuff except adding network devices to Clearpass tacacs server and I want to automate this process. For example when I create config for a network device, one of the playbook should be adding it to tacacs.
Highlighted
Moderator
It’s one API call so I’m not sure we could really provide a playbook for that.
Highlighted
I have a python code that get an api token and push the config to device. Can I have some help to convert it to Ansible module?
Highlighted
Hi, what is the difference between this and the aruba_config already supported in Ansible 2.4?
