Wired Intelligent Edge
Aruba CX VSX Connection between two pair of VSX cluster
This thread has been viewed 28 times
  • 1.  Aruba CX VSX Connection between two pair of VSX cluster
    Posted Jul 05, 2020 10:01 AM
    Hi all,
    I have attached the diagram of three tire Campus network topology,
    Here as per documents it seems like Core node with VSX is wins.
    My question here is I have One VSX cluster in Building A and One VSX cluster in Building B.
    I want to have L3 connectivity between them by bundling ports on both the VSX cluster
    is this possible ?
    Related to diagram attached what kind of link is shown between both VSX cluster.
    Thanks in advance
  • 2.  RE: Aruba CX VSX Connection between two pair of VSX cluster
    MVP GURU
    Posted Jul 07, 2020 02:44 PM
    can you make a schema what do you want/need ?
  • 3.  RE: Aruba CX VSX Connection between two pair of VSX cluster
    Posted Jul 12, 2020 09:47 AM
    Below is the sample diagram of what i want to achieve,
    I want to have L3 connectivity between CAMPUS BLDG & DC BLDG by means of having L3 Port-Channel.
    Earlier we were having comware series switch were we had created route aggregation between those two BLDG.
    Or what could be the best way to do so ?
  • 4.  RE: Aruba CX VSX Connection between two pair of VSX cluster
    MVP GURU
    Posted Jul 18, 2020 04:29 AM
    Yes, it is possible with ArubaCX to create L3 Lag interface
  • 5.  RE: Aruba CX VSX Connection between two pair of VSX cluster
    Posted Aug 04, 2020 08:50 AM
    In 10.3/10.4/10.5 you can create a L3 LAG on the same CX switch
    but not a L3 VSX LAG (MCLAG). This is not yet supported.
    For the above simple topology, I would suggest to use OSPF routing
    on each point-to-point L3 link. Typical convergence time in case of link failure should be less or equal to one second with default OSPF timer.
    If this is not fast enough, you can tune OSPF spf-throttling timers.
    The other alternative is to use VSX LAG between the VSX pairs, with transit VLAN (and associated SVI). This improves the convergence time down to few hundreds of milliseconds, if needed.
  • 6.  RE: Aruba CX VSX Connection between two pair of VSX cluster
    Posted Aug 10, 2020 07:03 AM
    Hi Vincent,
    As per your suggestion i have used OSPF.
    Thanks for your information
  • 7.  RE: Aruba CX VSX Connection between two pair of VSX cluster
    Posted Feb 05, 2021 03:06 AM
    Hi Harsh_P
    I am on the same schema  2 VSX and i would like to make OSPF point-to-point between us, but i'm lost whit the configuration can u help me please?
