Aruba Switch Automatic Certificate Download From Clearpass (XX.16.08.XXX)
MVP Expert
MVP Expert
Download The Certificate From Clearpass To The Switch
For this to work, two commands need to be added to the switch.  See Configuration below.
The following 2 commands will stay in the config.
It will also cause the certificate to download in .pem file format. I would recommend they be done in the order shown below.
   Switch(config)# radius-server host 10.206.163.107 clearpass
   Switch(config)# crypto ca-download usage clearpass retry 3
Now I have the certificate from Clearpass downloaded to the switch.
There will also be a corresponding log entry noting it was downloaded successfully.
TestAcs(config)# show crypto pki ta-profile
Profile Name   Profile Status                 CRL Configured  OCSP Configured
IDEVID_ROOT    Root Certificate Installed
user.user@h... Root Certificate Installed    No               No
COMODO_CA   Root Certificate Installed    No              No
GEOTRUST_CA  Root Certificate Installed    No             No
ARUBA_CA        Root Certificate Installed    No              N
ADDTRUST_CA Root Certificate Installed    No                o
o
NOTE:    See The Attached PDF For Additional Detail
Certificate_download_v2.pdf
Version history
Revision #:
1 of 1
Last update:
‎06-04-2019 04:51 PM
Updated by:
