Aruba Switch - How Does Spanning-Tree BPDU-Protection Operate?
MVP
MVP
Q:
How does Spanning-Tree BPDU-Protection operate?
A:
The spanning-tree bpdu-protection configuration disables the specific port or ports if the port(s) receives STP BPDUs.
In the following example, switch Rack2sw1 is configured for spanning-tree protocol and switch Rack2sw2 is configured with spanning-tree protocol disabled. Interface 24 on switch Rack2sw1 is configured for bpdu-protection.
Testing is accomplished by configuring spanning-tree on switch Rack2sw2. Interface 24 on switch Rack2sw1 changes state to inconsistent and a disable port spanning-tree message is logged.
********** Switch Rack2sw1 Configuration **********
Rack2sw1# show config | begin spanning-tree
spanning-tree
spanning-tree priority 0
Rack2sw1# show config interface 24
interface 24
   untagged vlan 12
********** Switch Spanning-Tree Verification **********
Rack2sw1# show spanning-tree | include CST
  CST Root MAC Address : 941882-a36540
  CST Root Priority    : 0
  CST Root Path Cost   : 0
  CST Root Port        : This switch is root
********** Enable Spanning-Tree on Switch 2 **********
Rack2sw2(config)# spanning-tree
********** Testing Verification **********
Rack2sw1# show spanning-tree inconsistent-ports
 Instance ID Blocked Port Reason
 CST         24           Bpdu Error
 CST         A1
 CST         A2
 CST         B1
 CST         B2
Rack2sw1# show logging -r
 Keys:   W=Warning   I=Information
         M=Major     D=Debug E=Error
----  Reverse event Log listing: Events Since Boot  ----
I 01/01/90 01:25:53 00898 ports: BPDU protect(5) has disabled port 24
Version history
Revision #:
1 of 1
Last update:
‎05-29-2020 07:14 AM
Updated by:
