Highlighted
MVP Expert
Aruba controllers and wired clients
Hi guys,
I have an Aruba controller (ArubaOS 8.2) and a RAP. This RAP is not broadcasting any SSID since clients are connected to the RAP's ports. Clients can transmit traffic and everything is fine, the only problem is I don't see clients in the controller dashboard, I guess the reason is they are wired clients and not wireless clients. This days I have to integrate the controller to AirWave, but I guess if I don't see wired clients in the controller, I will see the same in AirWave. Any suggestion?
Julián
Accepted Solutions
Highlighted
Moderator
Re: Aruba controllers and wired clients
Upgrade to 8.4
If this response is more than 1 year old, it may no longer be accurate. Please consult official Aruba documentation, TAC or your Aruba SE.
| Aruba Alumni | @timcappalli | timcappalli.me |
View solution in original post
All Replies
Highlighted
MVP Expert
It seems I have to set the ports as untrusted:
https://community.arubanetworks.com/t5/Wireless-Access/Show-wired-ap-users/td-p/273580
But after setting this and after rebotting the RAP twice, I don't see still any client.
This is the wired AP profile on the port the client is connected to:
This is the AAA profile:
And this is the initial role I have set within the AAA profile:
I see the following logs related to my client:
Any tip? Please your help!
Julián
Highlighted
MVP Expert
Hi guys,
Any idea? After checking more posts like the following
https://community.arubanetworks.com/t5/Wireless-Access/Provisioning-APs-to-do-802-1x-authentication-on-its-wired-uplink/td-p/90532
I don't see any clients yet. Even I rebooted the controller. I have enabled the 802.1x authentication in profile as suggested in the previous logs and I don't see them anymore, but still no wired clients in the controller's dashboard. All the post about the topic say to set the port as untrusted, which I have done, but without results. I guess is about my AAA, 802.1x authentication and wired port profiles, but I am not an expert on this and still stuck. Attached the controller configuration. Please I need your help.
Julián
Highlighted
Moderator
Upgrade to 8.4
Highlighted
MVP Expert
After upgrading to ArubaOS 8.4 I can see the wired clients :)
Is it a 8.2 bug? Many thanks Tim!
Julián
