This community is currently in a read-only state due to a maintenance window. For more info click here
Highlighted
Contributor II
Aruba switch replacement
What are the recommended steps to replace one aruba switch to another?
For e.g aruba 1950 to 2930 or 3810?
Highlighted
MVP Guru
Re: Aruba switch replacement
What are you asking?
HPE OfficeConnect 1950 Switch series is Comware 7 based...so it's not ArubaOS-Switch based as Aruba 2930F/M or Aruba 3810...are you asking moving from non-ArubaOS-Switch based Switch series to ArubaOS-Switch based series or just moving configuration within ArubaOS-Switch based Switch series?
Highlighted
Contributor II
Both.
