Aruba switch stacking
Can we stack Aruba 2930M 24G PoE+ 1-slot Switch (JL320A) with a Aruba 2930M 48G PoE+ 1-slot Switch (JL322A) ?
MVP
MVP
Re: Aruba switch stacking
Yes, you can stack different 2930M switches with different number of ports.
2930M use hardware stacking, so you need to add 2930M stacking modules in each switch and stacking cables.
See also this nice topic. https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/Backplane-Stacking-and-VSF-Best-Practices-for-ArubaOS-Switch/m-p/500559
Kind Regards Marcel Koedijk
HPE ASE Flexnetwork | ACMP | ACCP - Was this post usefull, Kudos are welcome.
Hi Lalitha
Maybe this manual can help you:
https://support.hpe.com/hpsc/doc/public/display?docId=a00015161en_us
Just search the key word: "stack" and you will find plenty information about stacking for 2930M.
Regards
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
