Wired Intelligent Edge
ArubaOS-CX 10.01.0020 is here!
  • 1.  ArubaOS-CX 10.01.0020 is here!
    MVP GURU
    Posted Sep 08, 2018 06:39 PM
    Hi all,
    ArubaOS-CX 10.01.0020 Software Images for both Aruba 8400 and Aruba 8320 have just been published.
    References:
    No enhancements were declared, the ArubaOS-CX 10.01.0020 provides only fixes.
  • 2.  RE: ArubaOS-CX 10.01.0020 is here!
    Posted Nov 09, 2018 03:52 AM
    Hi all
    Could anyone point me where to download 10.01.0020 please?
    In the download area, I can find only 10.01.0001.
    Fredy
  • 3.  RE: ArubaOS-CX 10.01.0020 is here!
    Posted Nov 09, 2018 04:02 AM
    you have to download via mynetworking portal. (maybe new auruba support portal is an option? old aruba support portal will not work) If you are a partner, remember to login to afp and use links there to go to mnp. Otherwise mnp will not recognize you as partner.
    Regards, Jö
  • 4.  RE: ArubaOS-CX 10.01.0020 is here!
    Posted Nov 09, 2018 04:21 AM
    Hello Jö
    Thank you for the very fast answer.
    For those struggling with the mynetworking portal.
    You first must register the product, before it lets you download the software. Otherwise it shows the software, but cannot find the download file.
    Cheers,
    Fredy
  • 5.  RE: ArubaOS-CX 10.01.0020 is here!
    MVP GURU
    Posted Nov 09, 2018 08:53 AM
    It's funny...this would probably open up a Pandora's box (or not)...but if you go to:
    https://asp.arubanetworks.com/downloads
    and apply a filter for Product Family (selecting Aruba Switches) and Product Series (Aruba 8320 Switch series or Aruba 8400 Switch series) magically ArubaOS-CX 10.01.0020 will appear freely downloadable among latest ArubaOS-CX 10.01.0030 (requires to be logged) and previous ones (they all require to be logged). See screenshot below (taken with me not logged in since I haven't requested an ASP account yet having the HPE one):
    ArubaOS-CX images on Aruba ASPArubaOS-CX images on Aruba ASP
    Is it a bug?
  • 6.  RE: ArubaOS-CX 10.01.0020 is here!
    Posted Sep 05, 2019 03:32 AM
    HI Wanted to know CX swithes support MVR & DVMRP ?
  • 7.  RE: ArubaOS-CX 10.01.0020 is here!
    MVP GURU
    Posted Sep 05, 2019 04:12 AM
    Hi! please open a new dedicated thread instead of using this one: hijacking an old thread with off-topic questions is not a Community best practice.
