Highlighted
MVP Guru
ArubaOS-CX 10.01 VSX: how to show split recovery feature status?
Hi, ArubaOS-CX 10.01.0030 introduced - enabled by default - the split-recovery feature for VSX (it's a parameter on vsx context).
Is there a way to understand if that feature is enabled or not (apart from presuming it is enabled - because that is default after any update to ArubaOS-CX 10.01.0030 - because node running configuration is not showing it with a prepend "no" assertion)?
Highlighted
MVP Guru
Re: ArubaOS-CX 10.01 VSX: how to show split recovery feature status?
That table should summarize and clarify (hopefully).
Please let me know.
Highlighted
MVP Guru
Hi Vincent, thanks...I already followed the discussion about that on the other thread...my question is more related to understand if doing a show vsx status the split-recovery option is clearly reported as enabled (withouth be forced to look for it into the running-config) or not...or if does it exist a dedicated show split-recovery command.
Davide.
Highlighted
MVP Guru
 show vsx configuration split-recovery
Split recovery info does not appear in show vsx status.
Highlighted
MVP Guru
Hi Giles,
the command you suggested above doesn't really exist on ArubaOS-CX 10.01.0030 (does came from a development version of ArubaOS-CX?):
Aruba-8320-1# show vsx status
VSX Operational State
  ISL channel             : In-Sync
  ISL mgmt channel        : operational
  Config Sync Status      : in-sync
  NAE                     : peer_reachable
  HTTPS Server            : peer_reachable
Attribute           Local               Peer
ISL link            lag128              lag128
ISL version         2                   2
System MAC          d0:67:26:XX:XX:XX   d0:67:26:YY:YY:YY
Platform            8320                8320
Software Version    TL.10.01.0030       TL.10.01.0030
Device Role         primary             secondary
Aruba-8320-1# show vsx configuration split-recovery
Invalid input: split-recovery
Aruba-8320-1# show vsx configuration ?
 inter-switch-link  Show current configuration of ISL
 keepalive          Show current configuration of keepalive
Am I missing anything?
Davide.
Highlighted
Contributor II
Hey Parnassus,
I don't see it either, if you type "list" you'll see a list of all available commands on the level you are currently on. If you do that on the base level, there is no "show xxx split-recovery" command, so I do believe it's not available just yet.
Something that I'm missing as well is a "show active-gateway" of any sort, per interface or in general, there is not such command either.
Cheers!
Aarón
Highlighted
MVP Guru
Hi Davide,
Correct it comes from CLI test on one version ahead (next 10.01..).
Highlighted
MVP Guru
Hi Giles,
I don't know if any software release of ArubaOS-CX 10.01 software branch post ArubaOS-CX 10.01.0030 finally introduced the command to verify the split-recovery status (enabled/disabled)...but, for sure, the command is available on latest ArubaOS-CX 10.02.0010:
Split Recovery Mode : Enabled
