Highlighted
MVP Guru
ArubaOS-CX 10.01: is LLDP over OoBM supported?
Is LLDP over OoBM (default vrf mgmt) supported on current ArubaOS-CX 10.01 for Aruba 8320/8400X platforms?
Highlighted
MVP Guru
Re: ArubaOS-CX 10.01: is LLDP over OoBM supported?
No it does not in 10.1.
Highlighted
MVP Guru
Is it already on the roadmap (as example for future release of ArubaOS-CX 10.02)?
Highlighted
MVP Guru
I'm not aware of LLDP over OOBM coming in 10.2.
Highlighted
MVP Guru
That's quite sad...
