Contributor II
ArubaOS-CX 10.02 PBR Documentation
I can't find any dicumentation on PBR for the new ArubaOS-CX.
I want to configure source based routing as the Release Note suggest that this should now be possible.
Re: ArubaOS-CX 10.02 PBR Documentation
Contributor II
I still can't find any documentation on PBR, will there be another Guide?
Yes, there will be a dedicated one for PBR.
In the meantime the steps are (to unlock you):
- configure a class and addresses/protocols you want to match on
- configure a pbr-action-list where you'll define default-nexthop, nexthop or interface
- create a policy where you apply the said prb-action-list to the previously configured class.
- finally apply the policy on a L3 interface (with routed-in keyword).
These are partial information, more complete information in the coming guide.
