Highlighted
MVP Guru
ArubaOS-CX 10.03.0020 is here!
Hi all,
ArubaOS-CX 10.03.0020 Software Images for Aruba 8400, Aruba 8325 and Aruba 8320 have just been published.
References:
Please refer to Release Notes provided on above links for a complete view of new features, enhancements and bug fixes introduced with this ArubaOS-CX software release.
Highlighted
MVP Guru Elite
Re: ArubaOS-CX 10.03.0020 is here!
There is also OVA/OVF available ! (for testing !)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
