Highlighted
MVP Guru
ArubaOS-CX 10.04.0001 is here!
Hi all,
ArubaOS-CX 10.04.0001 Software Images for Aruba 8400, Aruba 8325Aruba 8320, Aruba 6300 and Aruba 6400 Switch series have just been published.
References:
Please refer to Release Notes provided on above links for a complete view of new features, enhancements and bug fixes introduced with this ArubaOS-CX software release.
Highlighted
Re: ArubaOS-CX 10.04.0001 is here!
Is there any OVA file available for this release?
- Daniel Tudares (ACSP)
Highlighted
MVP Guru Elite
Yes !
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Link? I really can't seem to find it here https://asp.arubanetworks.com/downloads
Thanks!
Highlighted
MVP Guru Elite
Thanks!
No yet (no longer) available on ASP... but it is available on AFP
Highlighted
I got it! thanks a lot Alexis!
Highlighted
MVP Guru
This is being investigated...
Highlighted
MVP Guru
Well...to be honest ArubaOS-CX OVA images are (and were) available on ASP:
https://asp.arubanetworks.com/downloads/software/RmlsZTpkMWMyNTI3OC1mY2ZlLTExZTktYTcyMy1mZjU0OGFhMDNmMzA%3D
Specifying these filters will pop them up:
Highlighted
MVP Guru Elite
No yesterday...
Highlighted
Yeah, I really tried my best on looking and applying all the filters and checking on the different product families before asking here. It really wasn't there or was somehow hiden. I can see it now, thanks you all!
