Highlighted
MVP Guru
ArubaOS-CX 10.04.0041 is here!
Hi all,
ArubaOS-CX 10.04.0041 Software Images for Aruba 8400, Aruba 8325Aruba 8320, Aruba CX 6300 and Aruba CX 6400 Switch series have just been published.
References:
Please refer to Release Notes provided on above links for a complete view of new features, enhancements and bug fixes introduced with this ArubaOS-CX software release.
Note: As happened with ArubaOS-CX 10.04.0040 Release Notes for Aruba 6300F/M and Aruba 6400, the above published ArubaOS-CX 10.04.0041 Release Notes document for Aruba CX 6300 and Aruba CX 6400 Switch Series reports only the Aruba CX 6300 Switch Series as supported, totally lacking of any reference about Aruba 6400 Switch Series. See the original note on ArubaOS-CS 10.04.0040 thread here.
Edit 23rd May 2020: I'm more and more under the impression that Aruba 6400 should be deployed using ArubaOS-CX 10.04.1000 or 10.04.2000 because any previous version (e.g. 10.04.00xx) doesn't mention any support for it switch series. If this line of reasoning is correct then I should modify URLs titles accordingly, especially for latest ArubaOS-CX 10.04.00xx software releases announcement threads.
