Contributor I
ArubaOS-CX Multicast Guide for 10.03 <<< IGMP V2 ???
Re: ArubaOS-CX Multicast Guide for 10.03   IGMP V2
The multicast manual seems to indicate one can enable igmpv2.
I cannot.
My only option is:   ip igmp snooping"
CLI OUTPUT:
HPE-AOSCX8320(config-vlan)# ip igmp snooping
 Snooping Configurations
 drop-unknown Drop Unknown Configuration (Default: vlan-shared)
 fastlearn Configures the port to respond to topology changes
Question:    Any insight why snooping is the only option...am I missing something ???
# Thanks # Gracias # Merci # ありがとう # Danke # Spasiba # 감사합니다 # Toda # Cheers # Dhanyawaad # Ahsante # Xièxiè # shukran ##
Contributor I
Re: ArubaOS-CX Multicast Guide for 10.03 <<< IGMP V2 ???
ANSWER:
One must enable IGMP within the VLAN INTERFACE, sample below:
interface vlan999
ip address 10.10.0.99/19
ip helper-address 10.20.1.1
ip igmp enable
ip igmp version 2
