MVP Expert
Re: ArubaOS-CX Tacacs authentication
Yes, no possible for the moment...
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Did you try defining the source interface for the TACACS? Try adding:
ip source-interface tacacs <<MGMT IP HERE>>
 My switch was using some random VLAN in my default VRF as the source for TACACS. You can check to see if that's the case in the Event Viewer for ClearPass. You might see something like this:
Let me know if that helps!
MVP Expert
No, it is not the same issue...
MVP Expert
Do you have try last release ? (10.02.0020)
SSH
CR_37061
Symptom: The switch incorrectly sends a default blank password attempt.
Scenario: When logging into the switch through SSH, the switch incorrectly has an automatic attempt
to log in with a blank password before the user receives the password prompt.
Workaround: There is no functional impact. Console login does not have the additional login attempt.
