Highlighted
MVP Guru
ArubaOS-CX: VSX LAG's interface state (In-sync/Out-of-Sync) inconsistency?
I noticed that one of our interface (1/1/7 member of lag4 on both VSX nodes) shows a different state (Out-of-Sync versus In-Sync) respectively if the show lacp interfaces multi-chassis is committed on Primary or Secondary node (approximately during the same time):
Primary reports (truncated output, reported only lag4(mc)):
Aruba-8320-1# show lacp interfaces multi-chassis
State abbreviations :
A - Active        P - Passive      F - Aggregable I - Individual
S - Short-timeout L - Long-timeout N - InSync     O - OutofSync
C - Collecting    D - Distributing
X - State m/c expired              E - Default neighbor state
Actor details of all interfaces:
Intf    Aggregate  Port    Port     State   System-ID         System   Aggr
        name       id      Priority                           Priority Key
1/1/7   lag4(mc)   7       1        ALFNCD  d0:67:26:49:b8:9e 65534    4
1/1/8   lag4(mc)   8       1        ALFNCD  d0:67:26:49:b8:9e 65534    4
Partner details of all interfaces:
Intf    Aggregate  Partner Port     State   System-ID         System   Aggr
        name       Port-id Priority                           Priority Key
1/1/7   lag4(mc)   2       128      ALFNCD  98:be:94:66:18:30 32768    48879
1/1/8   lag4(mc)   6       128      ALFNCD  98:be:94:66:18:30 32768    48879
Remote Actor details of all interfaces:
1/1/7  lag4(mc)   1007    1        ALFNCD  d0:67:26:49:b8:9e 65534    4
1/1/8  lag4(mc)   1008    1        ALFNCD  d0:67:26:49:b8:9e 65534    4
Remote Partner details of all interfaces:
1/1/7  lag4(mc)   1       128      ALFNC   98:be:94:66:18:30 32768    48879
1/1/8  lag4(mc)   5       128      ALFNC   98:be:94:66:18:30 32768    48879
Secondary reports (truncated output, reported only lag4(mc)):
Aruba-8320-2# show lacp interfaces multi-chassis
1/1/7   lag4(mc)   1       128      ALFNCD  98:be:94:66:18:30 32768    48879
1/1/8   lag4(mc)   5       128      ALFNCD  98:be:94:66:18:30 32768    48879
1/1/7  lag4(mc)   7       1        ALFOCD  d0:67:26:49:b8:9e 65534    4
1/1/7  lag4(mc)   2       128      ALFNC   98:be:94:66:18:30 32768    48879
1/1/8  lag4(mc)   6       128      ALFNC   98:be:94:66:18:30 32768    48879
Notice how lag4(mc) 1/1/7 Interface's state (N versus O) is reported as Remote Actor from the VSX Secondary:
Isn't that a little bit strange?
How is it possible that the very same Interface 1/1/7 is concurrently seen In-Sync (N) and Out-of-Sync (O)?
Logs of VSX Primary: NO logs related to 1/1/7.
Logs of VSX Secondary:
2019-03-28:13:49:20.447160|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFO, Partner state ALFNCD
2019-03-28:13:49:20.815111|lacpd|1313|LOG_INFO|AMM|-|LAG 4 set as VSX
2019-03-28:13:49:20.816062|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALIO, Partner state PLIO
2019-03-28:13:49:20.818323|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFO, Partner state PLIO
2019-03-28:13:49:20.826889|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFO, Partner state PLFO
2019-03-28:13:49:20.830274|lacpd|1309|LOG_INFO|AMM|-|Partner is detected for interface 1/1/7 LAG 4 : 65534,00:00:00:00:00:00. Actor state: ALFOE, partner state PLFO
2019-03-28:13:49:20.830413|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFOE, Partner state PLFO
2019-03-28:13:49:20.833512|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFOE, Partner state PSFO
2019-03-28:13:49:20.836760|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFOX, Partner state PSFO
2019-03-28:13:49:20.840133|lacpd|1310|LOG_WARN|AMM|-|Partner is out of sync for interface 1/1/7 LAG sport: 15. Actor state: ALFOX, partner state PSFO
2019-03-28:13:49:21.349742|lacpd|1309|LOG_INFO|AMM|-|Partner is detected for interface 1/1/7 LAG 4 : 32768,98:be:94:66:18:30. Actor state: ALFOX, partner state ALFNC
2019-03-28:13:49:21.349819|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFOX, Partner state ALFNC
2019-03-28:13:49:21.353090|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFO, Partner state ALFNC
2019-03-28:13:49:23.034047|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFNCD, Partner state ALFNC
2019-03-28:13:49:23.347832|lacpd|1321|LOG_INFO|AMM|-|LAG 4 State change for interface 1/1/7: Actor state: ALFNCD, Partner state ALFNCD
 Any idea? Am I misunderstanding commands' outputs?
Highlighted
MVP Guru
Re: ArubaOS-CX: VSX LAG's interface state (In-sync/Out-of-Sync) inconsistency?
It seems a bug. Did you open a case ?
Highlighted
MVP Guru
Not yet. I'm going to open it just now on the Aruba Case Management Portal on ASP. Thanks.
Edit: opened Case number 5338235074.
