Highlighted
Occasional Contributor I
ArubaOS-CX VSX sync VLANs with ArubaOS-Switches
I want to implement an ArubaOS-CX Core with VSX and sync all the VLANs to our Access-/Aggregation-Switches. Until now, we've used MVRP for that but MVRP isn't compatible with VSX.
Is there any other way, to do this with ArubaOS-CX and ArubaOS?
Thanks!
Highlighted
MVP Guru Elite
Re: ArubaOS-CX VSX sync VLANs with ArubaOS-Switches
Use AirWave ? :D
Sorry, not yet supported protocol for this... (like MVRP on ArubaCX...)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
