Wired Intelligent Edge
ArubaOS-CX bgp route reflector
  • 1.  ArubaOS-CX bgp route reflector
    Posted Jul 28, 2020 08:40 AM
    Anyone got experience in bgp route reflector in ArubaOS-CX?
    got a vsx cluster configuret and got 2 neighbors that i configured with route reflector client, but the routes switch B get for router A dont goes to switch C.
    B is the RR and A & C i RR clients.
    I can see all routes on B from A but nothing on C, i can see the BGP neighbor is up for both.
    We run vrf but that shouldn't do anything.
    Router A is a RR.
    The only thing i can see is the neightbour x.x.x.x route-reflector-client command, do i need anything else?
    I can see in the bgp neighbor thats it says that C is a RR client but no routes is exchanged
    Thx.
  • 2.  RE: ArubaOS-CX bgp route reflector
    MVP GURU
    Posted Jul 28, 2020 04:13 PM
    What the use case ? EVPN ?
    Can you share the configuration ?
  • 3.  RE: ArubaOS-CX bgp route reflector
    Posted Jul 29, 2020 04:20 AM
    Hi its just regular routing, we allready use iBGP in our environment
     added a simple topology on what im doing.
    here's a sample of the config
    router bgp X
    bgp router-id X.X.X.X
    timers bgp 30 90
    vrf XXXX
    neighbor X.X.X.X remote-as X
    neighbor X.X.X.X password ciphertext XXXXXX
    address-family ipv4 unicast
    neighbor X.X.X.X activate
    neighbor X.X.X.X route-reflector-client
    exit-address-family
  • 4.  RE: ArubaOS-CX bgp route reflector
    Posted Jul 29, 2020 04:46 AM
    i think i found the issue, its a next hop self, see the routes in the bgp but they are not selected as they don't know the next hop, im trying to fix that with the next-hop-self cmd, ill update the post later.
