Highlighted
ArubaOS-CX can't delete "public" snmp community
By default the Aruba8320 uses the public community string. I configured a string called "private", and according to documentation, the public community should be removed automatically. However, that is not the case. When I try to remove the community manually, an error is returned:
switch(config)# no snmp-server community public
Community 'public' can't be deleted, as it is linked with another configuration.
This is the current snmp config:
switch# sh run | i snmp
snmp-server vrf default
snmp-server community private
snmp-server host x.x.x.x trap version v2c community private
switch# sh snmp comm
SNMP communities
private
public
Any ideas on how to remove the public community?
Highlighted
MVP Guru
Re: ArubaOS-CX can't delete "public" snmp community
Short test I made:
8320-3(config)# sh ru | inc snmp
snmp-server vrf mgmt
snmp-server system-description Lab 8320-3
snmp-server system-location Grenoble
snmp-server system-contact Vincent Giles
snmp-server community ArubA
vsx-sync aaa dhcp-server dns mclag-interfaces sflow-global snmp ssh time vsx-global
8320-3(config)# no snmp-server community public
You may try removing all other SNMP commands and then try again.
Highlighted
Removed all the snmp config so the snmp agent got disabled, but unfortunatly I still can't remove the public community. The switch keeps returning the same error message.
I am running code TL.10.02.0010
Highlighted
MVP Guru Elite
May be good to update (to last 10.02 or 10.03....)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
