Upcoming community maintenance Oct. 27th through Oct. 29th
For more info click here
Highlighted
MVP Guru
ArubaOS-CX: help diagnosing Tx Power warnings on SFP+ SR Transceiver
Greetings, suddenly one port of an VSX LAG equipped with a SFP+ SR Transceiver J9150D went down (it was a flip-flop then definitely down), Transceiver diagnostic shows Tx Low Power related warnings:
What conclusion can we gather about such diagnostic reports? SFP+ Transceiver temperature is few Celsius degrees higher than the average of all the others...and the issue seems to be only on trasmitting side...thanks for any insight you can provide!
Highlighted
MVP Guru Elite
Re: ArubaOS-CX: help diagnosing Tx Power warnings on SFP+ SR Transceiver
Try to replace ? (with a another ?)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
MVP Guru
Hi Alexis, sure I'm going to try and replace the SFP+ Transceiver on the Aruba 8320 side (clearly we have spare) but I asked that to understand if it is possible to infer some other information from diagnostic to see where the fault could be.
Highlighted
MVP Guru
Replaced with a spare (same SKU J9150D) and issue disappeared immediately. Open a case on ASP to request RMA.
