Highlighted
MVP Guru
Re: ArubaOS-CX on ESXI
This document may help you.
Highlighted
Contributor II
Doesn't mean to hijact this thread
I also want to try ArubaOS-CX ova in Eve-NG as I write for Mobility Controller here
https://nbctcp.wordpress.com/2015/07/02/unetlab-installation-on-esxi/
PROBLEMS:
1. I already request to Aruba community here in Indonesia to get ova. But didn't get any respond yet
Could someone from Aruba ask Aruba Indonesa to gimme OVA.
So that anyone want try ArubaOS-CX in Eve-NG just follow my steps
QUESTIONS:
1. is the command in ArubaOS-CX ova the same command as in physical switch
tq
Highlighted
MVP Guru Elite
PROBLEMS:
QUESTIONS:
tq
it is available on AFP or Support
Yes, it is the same command (but there is some limitation like not upgrade support...)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
Frequent Contributor I
While 10.2 Ova is available, still not able to get this running on ESXi 6.5. I want to run a full-size lab with VSX and MC-LAG upstream and downstream.
Also, the GNS3 appliance is not accessible, the link is broken nor is the appliance available.
I can't run a full lab on Virtualbox on my machine.
I have also looked through the afp.arubanetworks.com and I haven't had any success.
Highlighted
MVP Guru Elite
do you have change network settings on ESXI ?
Highlighted
Contributor II
ArubaOS-CX run perfectly on Eve-NG
just follow that link
Highlighted
MVP Guru
Highlighted
I have tried the GNS3 appliance and the link is broken
https://docs.gns3.com/appliances/aruba-arubaoscx.html
no is the disk image on the site - this feels like a non starter.
Going to rebuild the ESXi and give it another go.
Tried EVE-NG bare metal but I think the HDD drives need replacing.
Highlighted
MVP Guru
The GNS3 appliance URL that I gave works if you have Aruba For Partners access.
The GNS3 appliance is just a descriptor for Qemu. It does not contain the vmdk  that must be downloaded from ASP:
https://asp.arubanetworks.com/downloads/software/RmlsZTpjY2M3NjgzOC0yZTUyLTExZTktYjRkOC1iNzk5YmM1YTZmMmM%3D
Highlighted
While I have partner access and asp, none of those links gave me access.
The asp link to download the ova came up with the note to say it will be activated in 2 days.
I did get the GNS3 appliance from the afp.
I installed eve-ng on virtualbox and imported the OVA as described but yet to get that working.
