Highlighted
Contributor II
Re: ArubaOS-CX on ESXI
Your mistake is installing eve-ng on VirtualBox.
That won't run.
Install it on VMware Workstation.
Follow my link above on how to install eve-ng.
If still won't run email me on nbctcp@gmail.com
Highlighted
Frequent Contributor I
I have made some progress, I have the OS running in Eve-ng
I am interested to know about your network set-up, I have previously configured the mgmt for DHCP and connected to the interface which has allowed access from the PC by SSH.
In Eve-ng while I have an mgmt network connected, I can't figure which interface to attached the CX to, nor can i get a DHCP address.
How do you have EVE-NG configured?
Highlighted
MVP Guru
Mgmt interface is e0.
Like here:
Highlighted
I have given up with EVE-NG, spent 2 days trying in a number of formats,
Bare metal, EXI, VMplayer.
I can't get andy Cisco, nor connectivity to another VM nor get networking to a CX. That's across 3 different platforms, having read the cookbok and wait far too long for builds.
Going back to GNS3
Highlighted
MVP Guru
Contact me: vincent.giles@hpe.com, I'll help you.
I built the CX appliance for EVE-NG a while back, and can share how-to.
Highlighted
Frequent Contributor II
I have ArubaOS-CX on ESXi with GNS3-VM, but the Virtual Switches do not see each other. I don't see any mac in adress table or can ping another switch.
How to get 2 switches connected on GNS3-VM in ESXi?
Highlighted
MVP Guru Elite
What your vSwitch configuration ?
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
I have a vswitch without assigned NIC:
VLAN-ID  = none (0)
Promiscous-Mode = accept
MAC-Changes       = accept
Forged Transmits   = accept
In that Network is the GNS3-VM and a Gateway-VM
Nic of the AOS-CX are type virtio-net-pci
Highlighted
MVP Guru
Are you a partner ? (i.e do you have access to Arubapedia for partner - AFP ?)
Highlighted
Yes i am Partner and Using gns3a template from afp
