AOS Mobility Controller and ArubaOS Switch
Solution:In the following example, LACP protocol is configured on an AOS mobility controller and an ArubaOS switch.
---------- Mobility Controller Configuration ----------
(Standalone) [mynode] (config) #interface gigabitethernet 0/0/0
(Standalone) [mynode] (config-submode)#lacp group 1 mode active
(Standalone) ^[mynode] (config-submode)#interface gigabitethernet 0/0/1
(Standalone) ^[mynode] (config-submode)#lacp group 1 mode active
(Standalone) ^[mynode] (config-submode)#write memory
(Standalone) [mynode] (config) #interface port-channel 1
(Standalone) [mynode] (config-submode)#switchport mode trunk
(Standalone) ^[mynode] (config-submode)#switchport trunk allowed vlan 20
---------- Switch Configuration ----------
Core-Switch(config)# trunk 3,4 trk34 lacp
Core-Switch(config)# vlan 20 tagged trk34
---------- Mobility Controller Verification ----------
(Standalone) [mynode] #show lacp 1 neighbor
Flags: S - Device is requesting slow LACPDUs
F - Device is requesting fast LACPDUs
A - Device is in Active mode P - Device is in Passive mode
LACP Neighbor Table
Port Flags Pri OperKey State Num Dev Id
GE 0/0/0 SA 0 0x235 0x3d 0x3 54:80:28:B4:84:40
GE 0/0/1 SA 0 0x235 0x3d 0x4 54:80:28:B4:84:40
(Standalone) [mynode] #show vlan 20
VLAN CONFIGURATION
VLAN Description Ports AAA Profile Option-82
20 VLAN0020 Pc1 N/A Disabled
(Standalone) [mynode] #ping 10.0.20.1
Press 'q' to abort.
Sending 5, 92-byte ICMP Echos to 10.0.20.1, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 0.316/0.338/0.394 ms
---------- Switch Verification ----------
Core-Switch# show lacp peer
LACP Peer Information.
System ID: 548028-b48440
Local Local Port Oper LACP Tx
Port Trunk System ID Port Priority Key Mode Timer
3 Trk34 000b86-b5bad7 1 255 2 Active Slow
4 Trk34 000b86-b5bad7 2 255 2 Active Slow
Core-Switch# show vlan port trk34 detail
Status and Counters - VLAN Information - for ports Trk34
VLAN ID Name | Status Voice Jumbo Mode
1 DEFAULT_VLAN | Port-based No No Untagged
20 Local-Management-... | Port-based No No Tagged
Core-Switch# ping 10.0.20.2
10.0.20.2 is alive, time = 1 ms
40
