ArubaOS-Switch – How To Configure OSPF3 Routing
MVP
MVP
Aruba 2930F Switch running firmware version WC.16.10.0003
In the following examples, switches Rack2sw1 and Rack2sw2 are configured for OSPF3 routing.
---------- Rack2sw1 Configuration ----------
Rack2sw1# show running-config interface loopback 0
Running configuration:
   ip address 1.1.1.1
   ipv6 address 2003:1111::1
   ipv6 ospf3 area backbone
Rack2sw1# show running-config vlan 12
vlan 12
   name "VLAN12"
   tagged Trk12
   ipv6 enable
   ipv6 address 2003:12::1/124
Rack2sw1# show running-config router ospf3
router ospf3
   area backbone
   enable
---------- Rack2sw2 Configuration ----------
Rack2sw2# show running-config interface loopback 0
   ip address 2.2.2.2
   ipv6 address 2003::2222:1
Rack2sw2# show running-config vlan 12
vlan 12
   name "VLAN12"
   tagged Trk21
   ipv6 enable
   ipv6 address 2003:12::2/124
Rack2sw2# show running-config router ospf3
router ospf3
   area backbone
   enable
---------- Rack2sw1 Verification ----------
Rack2sw1# show ipv6
 Internet (IPv6) Service
  IPv6 Routing    : Enabled
  ND DAD          : Enabled
  DAD Attempts    : 3
                                VLAN Interfaces
  Interface Name  : DEFAULT_VLAN
  IPv6 Status     : Disabled
  Layer 3 Status  : Enabled
  Interface Name  : VLAN12
  IPv6 Status     : Enabled
  Address         |                                                       Address
  Origin            | IPv6 Address/Prefix Length       Status
  manual         | 2003:12::1/124                              preferred
  autoconfig   | fe80::2e59:e5ff:fe5f:6f00/64        preferred
  Interface Name  : VLAN13
  Interface Name  : VLAN23
                              Loopback Interfaces
  Loopback Name   : lo0
  Address     |                                                           Address
  manual      | 2003:1111::1/128                            preferred
Rack2sw1# show ipv6 ospf3 interface
 OSPFv3 configuration and statistics for Interfaces
 Interface    Status      Area ID       State   Cost    Pri   Passive
 vlan-12       Enabled  0.0.0.0         DR       1          1     No
 lo-0             Enabled  0.0.0.0         LOOP   n/a      n/a  n/a
Rack2sw1# show ipv6 ospf3 neighbor
 OSPFv3 Neighbor Information
 Interface   Router ID    Pri     State      Rxmt QLen  Events
 vlan-12     2.2.2.2          1       FULL       0                    5
Rack2sw1# show ipv6 route ospf3
                               IPv6 Route Entries
 T (Type):
  S: Static  C: Connected  O: OSPFv3  R: RIPng
 ST (Sub-type):
  O : OSPF Intra  E1: External1  N1: NSSA Ext1
  OI: OSPF Inter  E2: External2  N2: NSSA Ext2
 Destination/
  Gateway                                                             T   ST  Distance   Metric
 2003::222 2:1/128
 fe80::328d:99ff:fe8e:1180%vlan12                O   O   110              1
Rack2sw1# ping6 2003::2222:1
2003::2222:1 is alive, time = 5 ms
---------- Rack2sw2 Verification ----------
Rack2sw2# show ipv6
  ND DAD          : Enabled
  DAD Attempts    : 3
                                VLAN Interfaces
  Address        |                                                          Address
  manual        | 2003:12::2/124                              preferred
  autoconfig | fe80::328d:99ff:fe8e:1180/64       preferred
                              Loopback Interfaces
  Loopback Name   : lo0
  Address        |                                                         Address
  manual        | 2003::2222:1/128                            preferred
Rack2sw2# show ipv6 ospf3 interface
 vlan-12      Enabled  0.0.0.0         BDR      1          1       No
Rack2sw2# show ipv6 ospf3 neighbor
 vlan-12      1.1.1.1            1       FULL       0                    5
Rack2sw2# show ipv6 route ospf3
                               IPv6 Route Entries
 T (Type):
 ST (Sub-type):
 Destination/
 2003:1111::1/128
 fe80::2e59:e5ff:fe5f:6f00%vlan12                O   O  110             1
Rack2sw2# ping6 2003:1111::1
2003:1111::1 is alive, time = 3 ms
Version history
Revision #:
1 of 1
Last update:
‎04-27-2020 07:57 AM
Updated by:
