ArubaOS-Switch – How To Configure Pim Dense Mode Multicast Routing on Single Switch
MVP
MVP
ArubaOS Switch
In the following example, multicast routing is configured on an ArubaOS switch. A multicast sender is connected to port 18 and a multicast receiver is connected to port 9.
---------- Switch Configuration ----------
router pim
   enable
ip multicast-routing
interface 18
   name "Multicast-Sender"
   untagged vlan 104
vlan 104
   name "Multicast-Source"
   ip address 10.0.104.1 255.255.255.0
   ip pim-dense
interface 9
   name "Multicast-Receiver"
   tagged 108
vlan 108
   name "Multicast-Destination"
   ip address 10.0.108.1 255.255.255.0
   ip igmp
   ip pim-dense
---------- Switch Verification ----------
Rack2sw1# show ip pim
 PIM Global Parameters
  PIM Status                   :            Enabled
  State Refresh Interval (sec) :  60
  Join/Prune Interval (sec)       : 60
  SPT Threshold                        : Enabled
  Traps                                    :    none
Rack2sw1# show ip pim interface
 PIM Interfaces
  VLAN IP Address      Mode
  104  10.0.104.1      dense
  108  10.0.108.1      dense
Rack2sw1# show ip igmp vlan 108
 IGMP Service Protocol Info
  Total VLANs with IGMP enabled                      : 1
  Current count of multicast groups joined     : 1
  IGMP Filter Unknown Multicast: Disabled
  IGMP Filter Unknown Multicast Status: Disabled
  VLAN ID : 108
  VLAN Name : Standalone-VMC
  IGMP version : 2
  Querier Address [this switch] : 10.0.108.1
  Querier Port :
  Querier UpTime : 6d 23h 45m 3s
  Querier Expiration Time : 0h 0m 56s
  Active Group Addresses    Type        Expires         Ports         Reports    Queries
  239.0.82.11                          Filter       0h 3m 2s         9              4792          0
Rack2sw1# show ip igmp vlan 108 group  239.0.82.11
 IGMP ports and group information for group 239.0.82.11
 VLAN ID: 108
 Uptime: 6d 23h 48m 43s
 Last Reporter: 10.0.108.100
 Type: Filter
  Port    Port Type   Port Mode     Expires    Access
  9       1000T           Auto                246          host
Rack2sw1# show ip pim mroute 239.0.82.11 10.0.104.100
 IP Multicast Route Entry
  Group Address      : 239.0.82.11
  Source Address     : 10.0.104.100
  Neighbor                : 10.0.104.100
  VLAN                       : 104
  Up Time (sec)         : 26
  Expire Time (sec) : 209
  Multicast Routing Protocol : PIM-DM
  Unicast Routing Protocol   : connected
  Metric             : 1
  Metric Pref     : 0
  Assert Timer  : 0
  RP tree            : No
 Downstream Interfaces
  VLAN State           Up Time (sec)      Expire Time (sec)
  108  forwarding   26                          223
Rack2sw1# show vlans ports 18
 Status and Counters - VLAN Information - for ports 18
  VLAN ID Name                             | Status            Voice   Jumbo
  104     Multicast-Source               | Port-based   No       No
Rack2sw1# show vlan port 9
 Status and Counters - VLAN Information - for ports 9
  108     Multicast-Receiver           | Port-based   No       No
Rack2sw1# show interfaces 18 | include "B/Mcast Rx"
   B/Mcast Rx (Pkts/sec) : 116            B/Mcast Tx (Pkts/sec) : 0
Core-Switch# show interfaces 9 | include "B/Mcast Rx"
   B/Mcast Rx (Pkts/sec) : 5              B/Mcast Tx (Pkts/sec) : 119
Version history
Revision #:
1 of 1
Last update:
‎04-27-2020 07:48 AM
Updated by:
