ArubaOS-Switch – How To Configure Unicast Network Time Protocol (NTP)
MVP
MVP
ArubaOS Switch
In the following example, switch Rack2sw1 is configured for NTP unicast mode.
Rack2sw1(config)# no sntp
Rack2sw1(config)# ntp unicast
Rack2sw1(config)# ntp server 10.110.135.123
Rack2sw1(config)# ntp server-name "ntp.lab.net"
Rack2sw1(config)# ntp enable
Rack2sw1# show ntp status
 NTP Status Information
  NTP Status                         : Enabled                NTP Mode                : Unicast
  Synchronization Status    : Synchronized       Peer Dispersion     : 0.00000 sec
  Stratum Number              : 3                             Leap Direction        : 0
  Reference Assoc ID          : 0                              Clock Offset           : 0.20342 sec
  Reference ID                     : 10.110.135.123     Root Delay              : 0.03248 sec
  Precision                           : 2**-18                     Root Dispersion    : 0.91765 sec
  NTP Up Time                    : 23d 3h 50m            Time Resolution    : 819 nsec
  Drift                                   : 0.00051 sec/sec
  System Time                    : Sun Apr 26 02:44:59 2020
  Reference Time               : Sun Apr 26 01:27:41 2020
Rack2sw1# show ntp servers
                             NTP Server Information
 Server address
 10.110.135.123
 Server Name          Resolved Address      Server Status
 ntp.lan.net            10.110.135.123             Success: NTP server active
Rack2sw1# show ntp associations
                            NTP Associations Entries
 Remote                  St       T    When   Poll  Reach    Delay    Offset   Dispersion
 10.110.135.123     2        u    200      10      37          0.000    0.000    16.00000
Rack2sw1# show ntp statistics
 NTP Global statistics information
 NTP In Packets                         : 1569
 NTP Out Packets                      : 1569
 NTP Bad Version Packets       : 0
 NTP Protocol Error Packets   : 0
Rack2sw1# debug ntp packet
Rack2sw1# debug destination session
Rack2sw1# show debug
 Debug Logging
  Source IP Selection: Outgoing Interface
  Origin identifier: Outgoing Interface IP
  Destination:
   Session
   Memory buffer
  Time-stamp: System-Uptime
  Enabled debug types:
   ntp packet
0023:04:01:15.93 NTP  eNtpTask:Sent NTP Packet of 48 bytes to 10.110.135.123
0023:04:01:15.96 NTP  eNtpTask:NTP Packet of 48 bytes received from 10.110.135.123
0023:04:01:17.96 NTP  eNtpTask:Sent NTP Packet of 48 bytes to 10.110.135.123
0023:04:01:17.99 NTP  eNtpTask:NTP Packet of 48 bytes received from 10.110.135.123
Version history
Revision #:
1 of 1
Last update:
‎04-27-2020 07:33 AM
Updated by:
