ArubaOS-Switch – How to Configure OSPF Simple Authentication
MVP
MVP
Aruba 2930F Switch running firmware version WC.16.10.0003
In the following examples, switches Rack2sw1 and Rack2sw2 are configured for OSPF routing with simple authentication.
---------- OSPF Router Configuration ----------
Rack2sw1# show run router ospf
Running configuration:
router ospf
   area backbone
   enable
Rack2sw2# show run router ospf
router ospf
   area backbone
   enable
---------- OSPF Interface Configuration ----------
Rack2sw1# show running-config vlan 12
vlan 12
   name "VLAN12"
   tagged Trk12-Trk13
   ip address 192.168.12.1 255.255.255.0
   ip ospf 192.168.12.1 area backbone
   ip ospf 192.168.12.1 authentication-key "aruba123" <=====
Rack2sw2# show running-config vlan 12
vlan 12
   name "VLAN12"
   tagged Trk21,Trk23
   ip address 192.168.12.2 255.255.255.0
   ip ospf 192.168.12.2 area backbone
   ip ospf 192.168.12.2 authentication-key "aruba123" <======
---------- OSPF Interface Verification ----------
Rack2sw1# show ip ospf interface vlan 12
 OSPF configuration and statistics for VLAN 12
 OSPF Interface Status for 192.168.12.1
  IP Address      : 192.168.12.1        Status  : enabled
  Area ID         : backbone
  State  : BDR                          Auth-type : simple <=====
  Cost   : 1                            Chain     :
  Type   : BCAST                        Priority  : 1
  Transit Delay     : 1                 Retrans Interval  : 5
  Hello Interval    : 10                Rtr Dead Interval : 40
  Designated Router : 192.168.12.2      Events            : 0
  Backup Desig. Rtr : 192.168.12.1      Passive           : no
  Neighbors         : 1
Rack2sw2# show ip ospf interface vlan 12
 OSPF Interface Status for 192.168.12.2
  IP Address      : 192.168.12.2        Status  : enabled
  Area ID         : backbone
  State  : DR                           Auth-type : simple <=====
  Cost   : 1                            Chain     :
  Neighbors         : 1
---------- OSPF Debugging ----------
Rack2sw1# debug destination session
Rack2sw1# debug ip ospf packet
Rack2sw1# show debug
 Debug Logging
  Source IP Selection: Outgoing Interface
  Origin identifier: Outgoing Interface IP
  Destination:
   Session
  Enabled debug types:
   ip ospf packet
   ip ospf packet hello-packet
   ip ospf packet dd-packet
   ip ospf packet lsr-packet
   ip ospf packet lsu-packet
   ip ospf packet lsa-packet
The hex data “61727562 61313233” in the authentication data field has the ASCII value of “aruba123”
0000:21:15:10.37 OSPF eRouteCtrl:OSPF RECV: 192.168.12.2 -> 224.0.0.5: Version
   2, Type Hello (1), Length 48 ret 0
0000:21:15:10.54 OSPF eRouteCtrl:       Router ID 2.2.2.2, Area 0.0.0.0,
   Authentication <Simple> (1) <=====
0000:21:15:10.66 OSPF eRouteCtrl:       Authentication data: 61727562 61313233 <=====
0000:21:15:10.75 OSPF eRouteCtrl:       Mask 255.255.255, Options <E> (2), Priority 1,
   Neighbors 1
0000:21:15:10.87 OSPF eRouteCtrl:       Intervals: Hello 10s, Dead Router 40s,
   Designated Router 192.168.12.2, Backup 192.168.12.1
0000:21:15:11.03 OSPF eRouteCtrl:       Neighbors: 1.1.1.1
Version history
Revision #:
1 of 1
Last update:
‎04-15-2020 01:01 PM
Updated by:
