ArubaOS-Switch – How to Configure an IPV4 Access Control List (ACL) to Deny incoming IP Packets
MVP
MVP
ArubaOS Switches
In the following example, switches Rack2sw1 and Rack2sw2 are configured for IPV4 routing. Static routes are configured to enable IP connectivity between the loopback interfaces.
The access-list Deny_1_1_1_1 is applied inbound on switch Rack2sw1 Vlan 12. IP packets received with the source address 1.1.1.1 will be denied.
---------- Switch Configuration ----------
Rack2sw1# show running-config interface loopback 0
Running configuration:
   ip address 1.1.1.1
Rack2sw1# show running-config vlan 12
vlan 12
   name "VLAN12"
   tagged Trk12
   ip address 192.168.12.1 255.255.255.0
Rack2sw1(config)# ip route 2.2.2.2 255.255.255.255 192.168.12.2
Rack2sw2# show running-config interface loopback 0
   ip address 2.2.2.2
Rack2sw2# show running-config vlan 12
vlan 12
   name "VLAN12"
   tagged Trk21
   ip address 192.168.12.2 255.255.255.0
   ip access-group "Deny_1_1_1_1" vlan-in​
Rack2sw2(config)# ip route 1.1.1.1 255.255.255.255 192.168.12.1
Rack2sw2(config)# ip access-list extended Deny_1_1_1_1
Rack2sw2(config-ext-nacl)# deny ip host 1.1.1.1 any
Rack2sw2(config-ext-nacl)# permit ip any any
Rack2sw2(config)# vlan 12 ip access-group Deny_1_1_1_1 vlan-in
---------- Switch Verification ----------
Rack2sw1# show ip route
                                IP Route Entries
  Destination            Gateway          VLAN    Type               Sub-Type   Metric     Dist.
  1.1.1.1/32               lo0                                  connected                        1               0
  2.2.2.2/32              192.168.12.2    12         static                                1                1
  127.0.0.0/8            reject                              static                                 0                0
  127.0.0.1/32          lo0                                  connected                        1                0
  192.168.12.0/24    VLAN12          12           connected                        1               0
Rack2sw2# show ip route
                                IP Route Entries
  1.1.1.1/32              192.168.12.1    12         static                                  1               1
  2.2.2.2/32               lo0                                  connected                          1               0
---------- Access List Verification ----------
Rack2sw2# show access-list Deny_1_1_1_1
Access Control Lists
  Type: Extended
  Applied: Yes
 SEQ  Entry
 10   Action: deny
      Src IP: 1.1.1.1           Mask: 0.0.0.0                     Port(s):
      Dst IP: 0.0.0.0           Mask: 255.255.255.255   Port(s):
      Proto : IP
      TOS   : -                 Precedence: -
 20   Action: permit
      Src IP: 0.0.0.0           Mask: 255.255.255.255   Port(s):
      Proto : IP
---------- Testing -----------
Rack2sw1# ping 2.2.2.2 repetitions 5
2.2.2.2 is alive, iteration 1, time = 1 ms
2.2.2.2 is alive, iteration 2, time = 1 ms
2.2.2.2 is alive, iteration 3, time = 1 ms
2.2.2.2 is alive, iteration 4, time = 2 ms
2.2.2.2 is alive, iteration 5, time = 1 ms
Rack2sw1# ping 2.2.2.2 source loopback 0 repetitions 5
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Request timed out.
Rack2sw2# show statistics aclv4 Deny_1_1_1_1 vlan 12 vlan-in
 Hit Counts for ACL Deny_1_1_1_1
  Total
(       5 )    10 deny ip 1.1.1.1 0.0.0.0 0.0.0.0 255.255.255.255
(       5 )    20 permit ip 0.0.0.0 255.255.255.255 0.0.0.0 255.255.255.255
Version history
Revision #:
1 of 1
Last update:
‎04-27-2020 07:42 AM
Updated by:
