ArubaOS-Switch – How to Enable Debugging for OSPF Link-State Messages
MVP
MVP
Aruba 2930F Switch running firmware version WC.16.10.0003
The link-state advertisement (LSA) is a message type of the OSPF routing protocol for the Internet Protocol (IP). It communicates the router's local routing topology to all other local routers in the same OSPF area. Enabling debugging for OSPF lsa-generation will display these messages.
Rack2sw1# debug destination session
Rack2sw1# debug ip ospf lsa-generation
Rack2sw1# show debug
 Debug Logging
  Source IP Selection: Outgoing Interface
  Origin identifier: Outgoing Interface IP
  Destination:
   Session
  Time-stamp: System-Uptime
  Enabled debug types:
In the following debug output, the link state 11.11.11.11 is received from the Router-ID 1.1.1.1 and an acknowledgement sent.
0001:01:22:30.88 OSPF eRouteCtrl:OSPF SEND: 192.168.12.2 -> 224.0.0.5: Version 2, Type LS Acknowledgement (5), Length 44 ret 80
0001:01:22:31.02 OSPF eRouteCtrl:       Router ID 2.2.2.2, Area 0.0.0.0, Authentication <MD5> (2)
0001:01:22:31.12 OSPF eRouteCtrl:       Zero: 0, Key ID: 1, Length: 16, Sequence: 0
0001:01:22:31.20 OSPF eRouteCtrl:       AEX: Advrt 1.1.1.1 LSID 11.11.11.11 Age 6 Sequence 8000000b CkSum 3737 Length 36 Options <E DC>
Rack2sw2# show ip ospf external-link-state link-state-id 11.11.11.11
 OSPF External LSAs
  Link State ID   Router ID       Age  Sequence #  Checksum
  11.11.11.11     1.1.1.1         248  0x8000000b  0x00003737
Version history
Revision #:
1 of 1
Last update:
‎04-15-2020 12:51 PM
Updated by:
