ArubaOS-Switch – How to Enable Debugging for OSPF Neighbor Adjacency
MVP
MVP
Aruba 2930F Switch running firmware version WC.16.10.0003
While forming adjacency with each other, OSPF speaking neighbors go through several states before the routers are fully adjacent with each other. The state transitions can be displayed used OSPF debugging.
Rack2sw1# debug ip ospf event
Rack2sw1# debug destination session
Rack2sw1# show debug
 Debug Logging
  Source IP Selection: Outgoing Interface
  Origin identifier: Outgoing Interface IP
  Destination:
   Session
  Time-stamp: System-Uptime
  Enabled debug types:
   ip ospf event
0001:00:59:06.51 OSPF eRouteCtrl:OSPF STATE: NGB 1.1.1.1 EVENT 1-Way Received
0001:00:59:07.34 OSPF eRouteCtrl:OSPF STATE: NGB 1.1.1.1 EVENT Hello Received
0001:00:59:07.42 OSPF eRouteCtrl:OSPF STATE: NGB 1.1.1.1 EVENT 1-Way Received
0001:00:59:08.24 OSPF eRouteCtrl:OSPF STATE: NGB 1.1.1.1 EVENT 2-Way Received
0001:00:59:08.32 OSPF eRouteCtrl:OSPF STATE: NGB 192.168.12.1 change from <Init> to <2-Way>
0001:00:59:08.43 OSPF eRouteCtrl:OSPF STATE: number of full backbone neighbors is 2
0001:00:59:08.52 OSPF eRouteCtrl:OSPF STATE: NGB 192.168.12.1 change from <2-Way> to <ExStart>
0001:00:59:08.63 OSPF eRouteCtrl:OSPF STATE: number of full backbone neighbors is 2
0001:00:59:08.72 OSPF eRouteCtrl:OSPF STATE: INTERFACE 192.168.12.2 EVENT Neighbor Change
0001:00:59:08.82 OSPF eRouteCtrl:OSPF STATE: NGB 1.1.1.1 EVENT Adjacency OK?
0001:00:59:13.25 OSPF eRouteCtrl:OSPF STATE: NGB 1.1.1.1 EVENT Negotiation Done
0001:00:59:13.33 OSPF eRouteCtrl:OSPF STATE: NGB 192.168.12.1 change from <ExStart> to <Exchange>
0001:00:59:13.44 OSPF eRouteCtrl:OSPF STATE: number of full backbone neighbors is 2
0001:00:59:13.53 OSPF eRouteCtrl:OSPF STATE: NGB 1.1.1.1 EVENT Exchange Done
0001:00:59:13.61 OSPF eRouteCtrl:OSPF STATE: NGB 192.168.12.1 change from <Exchange> to <Full>
0001:00:59:13.72 OSPF eRouteCtrl:OSPF STATE: number of full backbone neighbors is 3
Version history
Revision #:
1 of 1
Last update:
‎04-15-2020 12:53 PM
Updated by:
