Aruba 2930F Switch running firmware version WC.16.10.0003
In the following example, debugging is enabled for user-based tunneled node messages with the destination set to buffer. Interface 18 is disabled and enable to log the message exchange.
Core-Switch# debug destination buffer Core-Switch# debug usertn Core-Switch# show debug
Debug Logging
Source IP Selection: Outgoing Interface Origin identifier: Outgoing Interface IP Destination: Memory buffer
Time-stamp: System-Uptime
Enabled debug types: usertn
Core-Switch(config)# interface 18 enable Core-Switch(config)# interface 18 disable
Core-Switch# show debug buffer
0001:18:21:04.15 TNT mtnodeUserCtrl:Bucket 172 initialized 0001:18:21:04.15 TNT mtnodeUserCtrl:10.0.10.2 uac->uitgReserve ZERO reserve 1 0001:18:21:04.15 TNT mtnodeUserCtrl:Entering userTNodeTCAMDecapReserveResources 0001:18:21:04.15 TNT mtnodeUserCtrl:User 000c29-21e66b added to tree 0001:18:21:04.15 TNT mtnodeUserCtrl:UAC Bootstrap to node: 10.0.10.2 0001:18:21:04.15 TNT mtnodeUserCtrl:userTNodeSendUACBStrapReq: Packet Sent Successfully 0001:18:21:04.15 TNT mtnodeUserCtrl:User 000c29-21e66b bootstrapping 0001:18:21:04.16 TNT mtnodeUserCtrl:create tunnel: port: 18 uac: 10.0.10.2 ifindex: 0 count: 0 0001:18:21:04.46 TNT mtnodeUserCtrl:User 000c29-21e66b tunneling to 318767764
0001:18:22:37.68 TNT mtnodeUserCtrl:000c29-21e66b bootstrapped state - remove hw rules 0 -1 0001:18:22:37.68 TNT mtnodeUserCtrl:1. port 18 ifindex 318767764 count 1 0001:18:22:37.68 TNT mtnodeUserCtrl:2. port 18 ifindex 318767764 count 0 0001:18:22:37.68 TNT mtnodeUserCtrl:Deleting tunnel for ifindex 318767764 0001:18:22:37.68 TNT mtnodeUserCtrl:10.0.10.2 uac->uitgReserve ZERO reserve 0 0001:18:22:37.68 TNT mtnodeUserCtrl:Entering userTNodeTCAMDecapReserveResources 0001:18:22:37.68 TNT mtnodeUserCtrl:UAC unbootstrap for reason: 5 to node: 10.0.10.2 0001:18:22:37.68 TNT mtnodeUserCtrl:userTNodeSendUACUnBStrapReq: Packet Sent Successfully 0001:18:22:37.68 TNT mtnodeUserCtrl:User 000c29-21e66b unbootstrapping 0001:18:22:37.68 TNT mtnodeUserCtrl:User 000c29-21e66b unBootstraped - node removed ** Total debug messages = 19
