Aruba 2930F Switch running firmware version WC.16.10.0003
In the following example, the Tunnel-Node-Server configuration is displayed, debugging is enabled for “IP Packets” with the buffer destination and the debug output displayed.
Core-Switch# show tunneled-node-server
Tunneled Node Server Information
State : Enabled Primary Controller : 10.0.10.2 Backup Controller : 10.0.10.4 Keepalive Interval (seconds) : 8 Mode : Role-based Vlan-Mode : vlan-extend-disable Reserved-Vlan : 4091
Core-Switch# debug destination buffer Core-Switch# debug ip packet Core-Switch# show debug
Debug Logging
Source IP Selection: Outgoing Interface Origin identifier: Outgoing Interface IP Destination: Memory buffer
Time-stamp: System-Uptime
Enabled debug types: ip packet
Keepalive messages are being sent every second.
Core-Switch# show debug buffer | include 10.0.10.4
0001:22:17:41.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:42.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:43.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:44.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:45.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:46.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:47.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:48.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:49.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:50.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:51.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:52.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:53.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:54.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:55.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:56.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:57.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:58.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:17:59.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:00.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:01.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:02.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:03.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:04.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:05.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:06.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:07.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:08.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:09.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:10.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:11.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:12.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:13.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:14.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:15.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:16.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:17.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit 0001:22:18:18.17 IP mtnodeUserCtrl:s=10.0.10.1 d=10.0.10.4(vl10) xmit
Core-Switch# no debug all
