ArubaOS-Switch – How to View per Process CPU Utilization
MVP
MVP
ArubaOS Switch
When CPU utilization is too high, switch performance is degraded. The cause may be found by looking at how much CPU utilization is used for each process. In the following example, switch Rack2sw1 is enabled for Process-Tracking.
Rack2sw1# process-tracking
ATTENTION: You are enabling the 'Process-Tracking' capability for the module.
            This can affect the performance of the module.
Do you want to enable Process-Tracking functionality [y/n]? y
Process-tracking started
Process-tracking time interval: 30 seconds
Rack2sw1# task-monitor cpu
Rack2sw1# show cpu process
Process tracker state: ACTIVE
Process tracking time: 30 seconds
                                                            Total          %     Time Since     Times        Max
  Process Name             Priority       Time       CPU     Last Ran         Ran         Time
                         Idle-1             226           2 s        42         92 us         46332        138 us
                         Idle-0             226           1 s        26       200 us         46259        313 us
                         Idle-3                 1      843 ms     21       142 us         93033        117 us
                      IPsec-3             146      129 ms      3          83 ms           1345         10 ms
                       TFTP-6             200      100 ms      2        152 us            1290          1 ms
 System Services-31             165        72 ms      1            3 ms           1216      342 us
                     HTTP-3              146        41 ms      1        484 ms             537      289 us
Version history
Revision #:
1 of 1
Last update:
‎04-27-2020 07:31 AM
Updated by:
