Highlighted
MVP Guru
ArubaOS-Switch VSF: does show system power-supply detailed report about PS of VSF Commander only?
Hi! On a VSF (two Aruba 5406R zl2) running on ArubaOS-Switch 16.05.0007 I was always used to see that the show system power-supply detailed CLI command reported details only for VSF Commander's powered PS Modules (PS1 and PS2) lacking totally about PS Modules inserted into the VSF Standby member.
Example:
VSF# show system fans
Fan Information
VSF-Member  1
  Num  | State       | Failures | Location
Sys-1  | Fan OK      |   0      | Fan Tray
Sys-2  | Fan OK      |   0      | Fan Tray
Sys-3  | Fan OK      |   0      | Fan Tray
Sys-4  | Fan OK      |   0      | Fan Tray
Sys-5  | Fan OK      |   0      | PS 1
Sys-6  | Fan OK      |   0      | PS 2
0 / 6 Fans in Failure State
0 / 6 Fans have been in Failure State
VSF-Member  2
VSF# show system power-supply detailed
 Status and Counters - Power Supply Detailed Information
  PS Model  Serial     State            Status
  1  J9829A CN6AKxxxxx Powered          AC Power Consumption : 83 Watts
                                        AC MAIN Voltage      : 229 Volts
                                        Power Supplied       : 63 Watts
                                        Power Capacity       : 1100 Watts
                                        Inlet Temp (C/F)     : 32.0C/89.6F
                                        Internal Temp (C/F)  : 50.4C/122.0F
                                        Fan 1 Speed          : 1080 RPM (31%)
                                        Fan 2 Speed          : 1125 RPM (33%)
  2  J9829A IN01Gxxxxx Powered          AC Power Consumption : 85 Watts
                                        AC MAIN Voltage      : 230 Volts
                                        Power Supplied       : 55 Watts
                                        Inlet Temp (C/F)     : 24.1C/75.2F
                                        Internal Temp (C/F)  : 34.4C/93.2F
                                        Fan 1 Speed          : 1600 RPM (47%)
                                        Fan 2 Speed          : 1600 RPM (47%)
   2 /  2 supply bays delivering power.
   Currently supplying 118 W / 2200 W total power.
   Refer to command's help option for field definitions
Is that a "bug" solved on newer software release or just the designed way the command was built?
Second question: is it normal to see those differences between PS1 and PS2 (recently changed due to a fault -> PS2 was made in India and newer than PS1 which was made in China)?
J9829A (Made in China) deployed as PS1
versus
J9829A (Made in India) deployed as PS2
Note that both PS Modules are on the same VSF Commander chassis...and I always looked at the temperature values reported by PS1 (and old PS2 now gone) as normal for the ambient temperature we know there is into the whole rack.
Accepted Solutions
Highlighted
Re: ArubaOS-Switch VSF: does show system power-supply detailed report about PS of VSF Commander only
It is a known issue that "show system power-supply detailed" command gives PS details of teh commander only on a stack/VSF
Fix is coming in CPE 29 (CR250966)
show system power-supply (without detailed option) works and that provides some info
View solution in original post
All Replies
Highlighted
Highlighted
MVP Guru
Hi! Thanks...it was the very first of my suspects. Out of curiosity what does CPE 29 mean? I know what CR means in this context (CR = Change Request)...but...does CPE 29 mean that next ArubaOS-Switch 16.10 software version incorporating the fix will be released during week 29th 2020?
Highlighted
As far as I know CPE means COLLEGES WITH POTENTIAL FOR EXCELLENCE.
CPE29
It is just numerically incrementing last release was CPE 28
Release CPE29: Expected in early-mid June (Please add a week or two buffer for communicating to customer during this Covid-19 pandemic)
Highlighted
MVP Guru
Gosh, mine was a joke!
I'm pretty sure that CPE is the acronym of Current Product Engineering (referred to a Software branch)...so, OK...it's CPE 29th...and thus the next stage will be the GA release, expected to be available in early-mid June 2020.
That's look good!
Thanks! Definitely, it's time for me to plan an update to that VSF.
