Aruba 2930F-Switch running firmware version WC.16.10.0003 and Aruba Mobility-Controller running firmware version 8.x
Solution:In the following example, switch Core-Switch and mobility controller StandaloneVMC are configured for Rapid-PVST (Rapid Per-Vlan Spanning Tree).
---------- Mobility Controller Configuration ----------
(StandaloneVMC) [mynode] #configure terminal
Enter Configuration commands, one per line. End with CNTL/Z
(StandaloneVMC) ^[mynode] (config) #spanning-tree mode rapid-pvst
(StandaloneVMC) ^[mynode] (config) #spanning-tree vlan 108
(StandaloneVMC) ^[mynode] (config) #interface gigabitethernet 0/0/0
(StandaloneVMC) ^[mynode] (config-submode)# spanning-tree
(StandaloneVMC) ^[mynode] (config-submode)#write memory
---------- Switch Configuration ----------
Core-Switch# configure terminal
Core-Switch(config)# spanning-tree
Core-Switch(config)# spanning-tree mode rapid-pvst
Core-Switch(config)# spanning-tree vlan 108 priority 0
---------- Mobility Controller Verification ----------
(StandaloneVMC) [mynode] #show spanning-tree interface gigabitethernet 0/0/0
Spanning Tree port configuration
Vlan State Cost Prio PortFast BpduGuard P-to-P Role
108 Forwarding 2000 128 Disable Disable Enable Root
(StandaloneVMC) [mynode] #show spantree vlan 108
Spanning tree instance vlan 108
Designated Root MAC 54:80:28:b4:84:40
Designated Root Priority 108
Root Cost 2000
Root Max Age 20 sec Hello Time 2 sec Forward Delay 15 sec
Bridge MAC 00:0c:29:a1:e3:16
Bridge Priority 32768
Configured Max Age 20 sec Hello Time 2 sec Forward Delay 15 sec
Rapid Spanning Tree port configuration
Port State Cost Prio PortFast BpduGuard P-to-P Role
GE 0/0/0 Forwarding 2000 128 Disable Disable Enable Root
(StandaloneVMC) [mynode] #show spanning-tree vlan 108
Spanning Tree instance for vlan 108
Spanning Tree is executing the IEEE compatible Rapid Spanning Tree protocol
Bridge Identifier has priority 32768, address 00:0c:29:a1:e3:16
Configured hello time 2, max age 20, forward delay 15
Current root has priority 108, address 54:80:28:b4:84:40
Topology change flag is not set , detected flag not set , changes 3
Times: hold 1, topology change 35 hello 2, max age 20, forward delay 15
Timers: hello 0, notification 0
Last topology change: 0 days, 0 hours, 5 mins, 12 secs
---------- Switch Verification ----------
Core-Switch# show spanning-tree vlan 108
Spanning Tree Information
STP Enabled [No] : Yes
Mode : RPVST
Extended System ID : Enabled
Ignore PVID Inconsistency : Disabled
Switch MAC Address : 548028-b48440
VLAN ID : 108
RPVST Enabled : Enabled
Root MAC Address : 548028-b48440
Root Priority : 0
Root Path Cost : 0
Root Port : This switch is root
Operational Hello Time (secs) : 2
Topology Change Count : 3
Time Since Last Change : 2 mins
Root Inconsistent Ports :
Loop Inconsistent Ports :
PVID Inconsistent Ports :
Designated
Port Type Cost Priority Role State Bridge
9 100/1000T 20000 128 Designated Forwarding 548028-b48440
