Wired Intelligent Edge
ArubaOS only allows single SSH connection
  • 1.  ArubaOS only allows single SSH connection
    Posted May 30, 2019 04:32 PM
    I configured an Aruba switch 3810 for AAA (Tacacs) with Clearpass but having 2 issues:
    - Switch is not allowing concurrent SSH conections, only the first connection works then everyone else gets "Connection refused"
    - How to disable the "username" prompt when entering "enable" mode? i am able to do this for Cisco switches but not for Aruba OS. I only want to ask user/password on initial conection then once enter enable mode only ask for password to match the previously entered username.
    AP
  • 2.  RE: ArubaOS only allows single SSH connection
    Posted May 31, 2019 10:25 AM
    For the double login issue you need to set the following command.
    aaa authentication login privilege-mode
    ArubaOS isn't restricting SSH to one session.
  • 3.  RE: ArubaOS only allows single SSH connection
    MVP GURU
    Posted Jun 05, 2019 09:01 AM
    What do you have on the log ?
    you don't have configure session limit ?
  • 4.  RE: ArubaOS only allows single SSH connection
    Posted Jun 05, 2019 11:58 AM
    I get "Connection closed" when trying to ssh when a user is already conected we get "Connection closed" refused from the switch,it doesnt even make it to CPPM......
    3810M-73-249# sho ip ssh
    SSH Enabled : Yes Secure Copy Enabled : No
    TCP Port Number : 22 Timeout (sec) : 120
    Rekey Enabled : No Rekey Time (min) : 60
    Rekey Volume (KB) : 1048576
    Host Key Type : RSA Host Key/Curve Size : 1024
    Ciphers : aes256-ctr,aes256-cbc,rijndael-cbc@lysator.liu.se,aes192-ctr,
    aes192-cbc,aes128-ctr,aes128-cbc,3des-cbc
    MACs : hmac-sha1-96,hmac-md5,hmac-sha1,hmac-md5-96
    Ses Type | Source IP Port
    1 console |
    2 ssh | 10.2.203.100 63166
    3 inactive |
    4 inactive |
    5 inactive |
    6 inactive |
    7 inactive |
  • 5.  RE: ArubaOS only allows single SSH connection
    MVP GURU
    Posted Jun 06, 2019 08:56 AM
    What firmware release ?
    Do you are using TACACS or RADIUS ?
  • 6.  RE: ArubaOS only allows single SSH connection
    Posted Jun 06, 2019 11:11 AM
    Tacacs
    Switch Boot ROM Version: KB.16.01.0008
    CPPM v 6.7.9
  • 7.  RE: ArubaOS only allows single SSH connection
    MVP GURU
    Posted Jun 06, 2019 12:06 PM
    what show version say ?
  • 8.  RE: ArubaOS only allows single SSH connection
    Posted Jun 06, 2019 12:19 PM
    3810M-73-249# show version
    Image stamp: /ws/swbuildm/rel_ukiah_qaoff/code/build/bom(swbuildm_rel_ukiah_qaoff_rel_ukiah)
    Jul 21 2017 14:42:33
    KB.16.04.0008
    442
    Boot Image: Primary
    Active Boot ROM: Primary
  • 9.  RE: ArubaOS only allows single SSH connection
    MVP GURU
    Posted Jun 06, 2019 01:41 PM
    May be a good idea to upgrade
  • 10.  RE: ArubaOS only allows single SSH connection
    Posted Jun 06, 2019 02:39 PM
    Greetings!
    First, check the number of maximum concurrent sessions currently configured on the switch using the command show console:
    switch# show console
     Console/Serial Link
      Active Console : Serial
      USB Console Input Enabled [Yes] : Yes
      Inbound Telnet Enabled [Yes] : Yes
      Web Agent Enabled [Yes] : No
      Terminal Type [VT100] : VT100
      Screen Refresh Interval (sec) [3] : 3
      Displayed Events [All] : All
      Baud Rate [speed-sense] : speed-sense
      Flow Control [XON/XOFF] : XON/XOFF
      Global Session Idle Timeout (sec) [0] : 0
      Serial/USB Console Idle Timeout (sec) [not set/900] : not set
      Current Session Idle Timeout (sec) : 0
      Maximum Concurrent Sessions Allowed [7] : 7
      Maximum Concurrent Sessions Allowed Per User [7] : 7
    If you need to change these values, use the commands console max-sessions and console max-user-sessions from the configuration context.
    If this does not appear to be causing the issue, I would recommend upgrading the switch to the latest software release (KB.16.08.0003), if possible, and seeing if the issue persists. If it does, I would recommend opening a TAC case (if you haven't already) for a formal investigation.
  • 11.  RE: ArubaOS only allows single SSH connection
    Posted Jun 06, 2019 02:49 PM
    Console settings eems to be ok, still get "Conection closed" as soon as i try a second ssh conection into the switch
    BH-ASE-SunCom-AEdge-3810M-73-249# show console
    Console/Serial Link
    Inbound Telnet Enabled [Yes] : No
    Web Agent Enabled [Yes] : Yes
    Global Session Idle Timeout (sec) [0] : 600
    Serial/USB Console Idle Timeout (sec) [not set/900] : 600
    Current Session Idle Timeout (sec) : 600
    Maximum Concurrent Sessions Allowed [7] : 6
    Maximum Concurrent Sessions Allowed Per User [7] : 6
