Does Aruba switch support Digital Optical Monitoring (DOM)?
https://community.cisco.com/t5/network-architecture-documents/digital-optical-monitoring-dom/ta-p/3120342
I'm quite confused about the Diagnostics Optical Monitoring is the same or not.
http://h22208.www2.hpe.com/eginfolib/networking/docs/switches/WB/15-18/5998-8162_wb_2920_mcg/content/ch11s05.html
You must check (Optical) Transceivers details to understand if DOM is supported or not.
Look at this guide.
Thanks for the quick reply.
Just to make sure if I've understood the concept, I can't say that the switch has Digital Optical Monitoring, but the transceiver itself. Is that right?
Correct. The switch (both in terms of Hardware and Software) should support DOM but DOM is essentially an Hardware/Software feature embedded into (or not embedded at all, if absent) optical Transceivers.
