Automatic config downloads
We're currently deploying Aruba 2930F switches in our access network in replacement of our old Ciscos.
We have an automated procedure to grab configuration off all network devices, compare them withj yesterday's versions and send the diffs to relevant people. This is done over SSH with public-key authentication to avoid using passwords.
Problem is, ArubaOS doesn't support public-key authentication when AAA is configured for TACACS, which we need to be able to login.
Anybody here doing something similar and wanting to share? I know we can do this with Airwave, but we're not sure we're going to use that platform at the moment (being quite new to the Aruba series of products).
Lars
MVP Expert
Re: Automatic config downloads
@ljorg wrote:
Problem is, ArubaOS doesn't support public-key authentication when AAA is configured for TACACS, which we need to be able to login.,
Lars
About public-key and AAA, what firmware do you using ? there is some change with last 16.08 about this
Do you have look to use API (and not SSH ?)
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
We're on 16.08. Nothing's changed.
Right now I have a workaround using sshpass on the Linux side (the config collector). Not too pretty, but it works and I have authenticated and encrypted transfers of config files.
Haven't looked at the APIs. Is there a manual for those?
Lars
MVP Expert
Lars
there is a API guide on HPE support website..
MVP Expert
The REST API Guide for 16.08 is available in PDF and HTML formats on the Networking Information Library
Matt Fern
Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
