MVP Expert
Backplane Stacking and VSF Best Practices for ArubaOS-Switch
Greetings!
We have developed a guide detailing best practices for deploying and maintaining backplane stacking and VSF on ArubaOS-Switch. The guide contains recommendations for deployment methods, maintenance, troubleshooting, and plenty of configuration examples.
The attached guide covers the 2930F, 2930M, 3810M, and 5400R switch series.
Matt Fern
Technical Marketing Engineer, Wired Intelligent Edge
Aruba, a Hewlett Packard Enterprise company
8000 FOOTHILLS BLVD  |  ROSEVILLE, CA 95747
T: 916.540.1759  |  E: mfern@hpe.com   |   Matt @ Twitter
MVP Expert
Re: Backplane Stacking and VSF Best Practices for ArubaOS-Switch
The guide has been updated with corrections to the backplane stack and VSF member replacement procedures, clarification to guidelines for mixing switch models within a stack or VSF fabric, and various formatting fixes.
Please feel free to respond to this thread with any issues, suggestions, or other feedback!
Matt Fern
MVP Expert
Hi Matthew,
Just two suggestion: first, on Timings appendix there is a wording that is not totally clear to me...take "Member addition" time on "2930F VSF (4 members)" paragraph: is it referring to VSF non sequenced update or to a VSF Member addition to an existing VSF fabric?
If the former is true maybe the "Member addition" wording should be changed into a more suitable "Member SW update".
Then a second thing: always on the same appendix...the statement "with brief traffic interruption on aggregated links when second member reboots" used on "5400R VSF (2 members)" paragraph is suggesting an global LAG traffic interruption (indeed using "...aggregated links..." doesn't help the reader to understand which physical links of the aggreagate will go down and which not) and not, more correctly, the fact that each LAG with links distributed to both VSF Member will just lose its physical links terminated into the VSF Member that is rebooting for update.
MVP Expert
On the first point: the timing entry for "Member addition" is for adding a new member to the fabric, from the point where the member is powered on (with cables connected to a VSF port on an existing member) to switch ports coming up after the switch has joined the fabric.
As for the second point: the physical links to the rebooting chassis will go down; this can cause a brief interruption on a LAG as traffic flows utilizing the (now down) link to the remaining active link, with the duration of interruption varying by protocol (see the timings on page 2 of the document linked in this post for more details; the table will be integrated into a future revision of the best practices guide).
Matt Fern
MG
Thanks very much for the guide. Deploying a 3810m stack at the moment and the info on OOBM is just in time.
Occasional Contributor I
Hey Matthew, thank you for the document! I have a qusetion that you can help me. If I have more than 1 switch in stack mode (2930M), is it possibile to sync the OSPF informations (protocol sync)?
MVP Expert
The stack behaves as a single logical switch, so protocol state (including OSPF) is automatically synced across the entire stack (no manual steps are required).
Matt Fern
MVP Expert
The guide has been updated with a minor revision to add VSF OoBM-MAD configuration for the 5400R.
Matt Fern
Is it officially supported to stack devices in VSF even if they are in different racks or wiring closets?
Thanks a lot
MVP Expert
@rronsse wrote: Is it officially supported to stack devices in VSF even if they are in different racks or wiring closets?
Yes, it's not important where you install your VSF Members...it's important how you interconnect them: if VSF ports are deployed using SFP/SFP+/QSFP+ Transceivers or DAC Cables then VSF Members connectivity restrictions became really SFP/SFP+/QSFP+ or DAC Cable restrictions (length)...imagine you have VSF Member 1 on Site A and VSF Member 2 on Site B, between Site A and B there are 30 km of (various) fiber optic cables "point to point" then you can easily deploy a VSF solution that is spread across distant sites (clearly with DAC Cables the maximum distance is measured in few meters...so when you are going to use DACs then it means you have VSF Members very near each others...generally on the very same room on the very same rack or on very near racks).
