Broadcast suppression pps
Hi all,
I want to limit the broadcast traffic on uplinks to 300pps.
Is there a CLI command for it? I only see the CLI commands for working with percentages.
Kind regards,
Regular Contributor I
Re: Broadcast suppression pps
You can configure percentage or kbp/s. so not in pps, but i think percentage is a always feasible solution.
example:
# interface 1/1
# rate-limit bcast in kbps 100
# rate-limit bcast in percentage 5
- - - - Aruba ACCX #748, ACDX #758, ACMP, ACEAP | HPE Master ASE - - - -
- - - - - - - Feel free to give kudos or accept as a solution! - - - - - - - - -
Is 5 percent not very low? I'm using 25 percent?
Kind regards,
