Wired Intelligent Edge
Bug enables operator user to reboot switch
  • 1.  Bug enables operator user to reboot switch
    Posted Feb 14, 2020 10:12 AM
    Hi all,
    a customer and I found a bug that enables operator privilege users to reboot AOS-S switches/stacks.
    I will not include the exact procedure to replicate the bug here.
    I just wanted to make sure this is not intended behavior.
    Should I just open a case for this?
    Regards
  • 2.  RE: Bug enables operator user to reboot switch
    Posted Feb 14, 2020 10:18 AM
    Absolutely
  • 3.  RE: Bug enables operator user to reboot switch
    Posted Nov 26, 2021 11:35 AM
    Hi, could you elaborate on this bug, I think I might be having the same issue, my stack suddenly rebooted and this is from boot-history:
    Member 1
    Master -- Saved Crash Information (most recent first):
    Active/Commander system went down: 11/24/21 11:52:47 WC.16.09.0003 516
    NMI event SW:PC=0x00000001 LR:0x034d1200 SP:0xf7 Task='mDsnoopCtrl' Task ID=0x2ab47298
    Standby system went down: 05/23/20 15:33:31 WC.16.09.0003 516
    Reboot of Member ID 1, User reboot
    Active/Commander system went down: 05/23/20 15:07:17 WC.16.09.0003 516
    Active/Commander system went down: 05/23/20 15:06:50 WC.16.09.0003 516
    Operator cold reboot from TELNET session.
    Manny Taveroff
