Can I disable EEE on Aruba 3810M switches?
I'm looking through the "HPE ArubaOS-Switch Management and Configuration Guide K/KA/KB.16.02 ", and I can't find any reference to this.
Switch is JL074A.
-Is this the correct guide for a new switch purchased this month?
-Can I disable the EEE? I need to do this for my Dante network.
Re: Can I disable EEE on Aruba 3810M switches?
EEE is off by default, to disable, you'd do so from the interface context like so:
UBT-Demo(config)# int 1/3
UBT-Demo(eth-1/3)# no energy-efficient-ethernet
The latest manuals are software are found on the aruba support portal - asp.arubanetworks.com.
The EEE section is found in the Basic Operation Guide:
http://h22208.www2.hpe.com/eginfolib/Aruba/16.08/5200-5493/index.html#i1311447.html
