Highlighted
MVP Guru Elite
Re: ClearPass assigned Voice VLAN on ArubaOS switches with LLDP-MED
@Chris.Denham wrote:
From the release notes, for posterity:
Bypassing Authentication for VoIP phones With 16.08,
customers can bypass authentication for certain wired devices such as VoIP phones while still allowing the clients behind the phones to authenticate. For more information, see the Access Security Guide
I think more to this feature :
Device Attributes for User Roles
To simplify deployment scenarios involving APs, AOS-Switch now allows device level configurations to be added
to User Roles. For more information, see the Access Security Guide
It is possible to make this :
aaa authorization user-role name “AP”
    vlan-id 101
    vlan-id-tagged 120,121
    device
        port-mode
        admin-edge-port
    exit
exit
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
