Highlighted
Compatibility Cisco QSFP-40/100-SRBD transceiver with Aruba 40G QSFP+ LC BiDi 150m MMF
I have to connect an 8320 with Aruba 40G QSFP+ LC BiDi 150m MMF (JL308A) with a Cisco Nexus which use the Cisco QSFP-40/100-SRBD transceiver.
Due to the datasheet the Aruba transceiver works with 850 nm
and Cisco works with 855 nm
Is it possible to build up a link between those transceiver?
Frank
Highlighted
Re: Compatibility Cisco QSFP-40/100-SRBD transceiver with Aruba 40G QSFP+ LC BiDi 150m MMF
Hi Frank,
As far as I know, nowadays 40GE bidirectional transceivers are prorietary, they do not follow a IEEE standard, so the only way to know if the transceivers you mentioned work together it is trying them on the field.
Regards
PS: If you feel this information is useful and solved your question or problem, please do not forget to mark it as a solution and give me some kudos.
