Concurrent SSH sessions and how to kill one or more SSH sessions.
MVP
MVP
Q:
How many concurrent SSH sessions are supported and how to Kill a particular SSH session?
A:
Aruba HPE Switch allows 5 concurrent SSH sessions. Executing "show ip ssh" will show the list of active SSH session and using Kill command, user can kill any SSH session as needed.
  • Below example shows 5 active SSH sessions,
Sunill-3810M(config)# show ip ssh
  SSH Enabled     : Yes                 Secure Copy Enabled : No
  TCP Port Number : 22                  Timeout (sec)       : 120
  Rekey Enabled   : No                  Rekey Time (min)    : 60
                                        Rekey Volume (KB)   : 1048576
  Host Key Type   : RSA                 Host Key/Curve Size : 2048
  Ciphers : aes256-ctr,aes256-cbc,rijndael-cbc@lysator.liu.se,aes192-ctr,
            aes192-cbc,aes128-ctr,aes128-cbc,3des-cbc
  MACs    : hmac-sha1-96,hmac-md5,hmac-sha1,hmac-md5-96
  Ses Type     | Source IP                                      Port
  1   console  |
  2   ssh      | 15.110.204.11                                  63776
  3   ssh      | 15.110.204.11                                  58187
  4   ssh      | 15.110.204.11                                  58194
  5   ssh      | 15.110.204.11                                  58201
  6   ssh      | 15.110.204.11                                  58209
  7   inactive |
  • To kill any one or more, executing Kill <ssh session ID> will kill that particular session.
  • In the below example, session 6 was killed.
Sunill-3810M# kill 6
Sunill-3810M#
Sunill-3810M# show ip ssh
  1   console  |
  6   inactive |
  7   inactive |
Version history
Revision #:
1 of 1
Last update:
‎09-18-2018 11:19 AM
Updated by:
