Contributor I
Configuration Commands Guide & Fimware Image Details for Aruba 2930F Switches
Dear Team,
could you please share Configuration Commands Guide & Supported /Available firmware details for below mentioned Aruba Switch.
Switch Part Numbers: JL254A, JL260A
Model: Aruba 2930F
Installed Software Version:
Image stamp:
/ws/swbuildm/rel_xanadu_zeus_qaoff/code/build/lvm(swbuildm_rel_xanadu_zeus_qaof
f_rel_xanadu_zeus)
Jul 12 2019 07:57:56
WC.16.07.0006
245
Boot Image: Primary
Boot ROM Version: WC.16.01.0006
Active Boot ROM: Primary
Note: Default Image come with this switch is WC.16.05.0007 (we have upgraded to WC.16.07.0006.
MVP Expert
Re: Configuration Commands Guide & Fimware Image Details for Aruba 2930F Switches
Hi Shayan
Go to https://asp.arubanetworks.com for get last firmware and documentation
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
ACMP 6.4 / ACMX #107 / ACCP 6.5
Hi alagoutte,
Could you please share URL to get the configuration command guide (installed Software Image on the switch: WC_16_08_0006), we didn't find any documentation for this series (WC_169_x) software image all are related with Aruba-OS.
We need to familiar with configuration commands for below mentioned:
  • VLAN, Interface Tagging.
  • Port Trunking (Bundling) /Etherchanneling /LACP.
  • Routing
  • Access-Lists
  • User Management
  • DHCP Server Configuration.
  • DHCP Relay
  • Spanning Tree (STP)
  • VSF
More need to understand.
MVP Expert
Greetings AASAMEDT and welcome to Aruba Airheads Community!
If I were you - with true desire to understand - I would first start by familiarizing with Aruba 2930F Documentation Map (direct link to PDF)...as you will see that map covers almost all you need into separated specific categories:
  1. Setting up
  2. Installing
  3. Planning and Implementing PoE/PoE+
  4. Operating
  5. Securing access
  6. Managing and Configuring
  7. Routing Multicast Traffic
  8. Managing Traffic
  9. Using IPv6 protocols
Then...if something is unclear or not well explained...for other deep dive guides/presentation/threads you could easily use the always valid tools like: Search Airheads (watch top right in this page, play with filter), ASP at asp.arubanetworks.com, HPE Community at community.hpe.com (Networking Forum) and support.hpe.com too. Plenty of choices...
