Highlighted
Frequent Contributor II
Configuration migration from 5406zl to 5406zl2
Hello All,
I'm planning to replace 5406zl  with the new Aruba 5406zl2,
to migrate the configuration the existing configuration I'm thinking about something easy like copy/past running configuration from old zl to the new zl2 ... is that right ?
is there any guide/recommendations/best practice for that?
Accepted Solutions
Highlighted
MVP Expert
Re: Configuration migration from 5406zl to 5406zl2
The configuration is almost the same. If you are going to use VSF you need to update the port numbers.
But if the port numbering is almost the same copy/past should work. Depends also on the complexity of the configuration
Willem Bargeman ACMX#935 | ACCX #822
Please give me kudos if my post was useful!
If your issue is solved mark the post as solution!
View solution in original post
All Replies
Highlighted
MVP Expert
