Configuring Mac Lockdown on 2540
New to Aruba, looking for some documentation or info on the best way to implement a mac lockdown on an Aruba 2540-24G. Basically we need to make sure the switch is only accessed by a number of known laptops, we are assuming mac lockdown is the way to go. (and we aren't clear on how to implement it)
Appreciate any suggestions.
Thank You
MVP Expert
Re: Configuring Mac Lockdown on 2540
Greetings!
Your requirement should fall within "Port Security", "MAC Lockdown" (these two are mutually exclusive) and "MAC Lockout" features, all those security features are detailed on Chapter 25 of the Aruba 2540 Access Security Guide for ArubaOS-Switch 16.08.
