Highlighted
Configuring VRF on ArubaOS-CX - Checklist
Virtual Routing and Forwarding:
Virtual Routing and Forwarding (VRF) is a Layer 3 level isolation to achieve Virtual Private Network (VPN).
Virtual routing and forwarding (VRF) is a technology that allows multiple instances of a routing table to co-exist within the same router.
Because the routing instances are independent, the same or overlapping IP addresses can be used without conflicting with each other.
Network functionality is improved because network paths can be segmented without requiring multiple routers.
Network Diagram:AOS-CX-VRFjpg.jpg
ABBREVIATION:
HB: Heartbeat Link
VSX: Virtual Switching Extension
MC-LAG: Multi-chassis LAG
VRF: Virtual Routing and Forwarding
Checklist for configuring VRF on AOS-CX Switch:
It about using the command “vrf attach” to the L3 Interface.
We got two VRF here.,
Default: 172.30.29.0/24                TRANSIT SUBNET: 10.10.101.2
DOE: 10.10.200.0/24                    TRANSIT SUBNET: 10.10.102.2
The transit subnet should also be a part of the VRF.
Since we only got one link from AOS-CX to 7005 Gateway, the links needs to be configured as trunk with multiple VLAN L3 interface, one for each VRF.
Create the VRF:
vrf DOE
Create the VLANs:
vlan 102
    name DOE_Transit_Subnet
vlan 200
    name DOE-Network
Define the connection mode and VLAN tagging:
interface lag 1 multi-chassis   //Connection between 2930M and AOS-CX
    vsx-sync vlans
    no shutdown
    description MC-LAG
    no routing
    vlan trunk native 101
    vlan trunk allowed all
    lacp mode active
interface 1/1/32
    no shutdown
    description From_2930M_Distribution_MCLAG
    lag 1
interface 1/1/48     //Connection between the AOS-CX and the 7005 G/W
    no shutdown
    description To_7005_Gateway
    no routing
Doing the VRF Attach:
interface vlan102
    vsx-sync active-gateways
    vrf attach DOE
    description DOE-Network
    ip address 10.10.102.12/24
    active-gateway ip mac 00:00:00:00:02:00
    active-gateway ip 10.10.102.2
interface vlan200
    vrf attach DOE
    ip address 10.10.200.2/24
    active-gateway ip 10.10.200.1
Remember to configure default Gateway on AOS-CX for each VRF:
ip route 0.0.0.0/0 10.10.102.1 vrf DOE                     //For VRF “DOE”
ip route 0.0.0.0/0 10.10.101.1                                  //For VRF “Default”
Also add the reverse route on the 7005 Gateway:
ip route 10.10.200.0 255.255.255.0 10.10.102.2       //For VRF “DOE”
ip route 172.30.29.0 255.255.255.0 10.10.101.2      //For VRF “Default”
In order to know how to configure VSX and MC-LAG, please refer the below link
https://community.arubanetworks.com/t5/Wired-Intelligent-Edge-Campus/ArubaOS-CX-Switches-VSX-and-MC-LAG/m-p/617685#M7734
VERIFICATION:
Routing Table: show ip route
Checking the clients Pingability:Client Pinging.jpg
Hope you find this post useful !
Highlighted
Re: Configuring VRF on ArubaOS-CX - Checklist
Are the VRF/routing limits documented somwhere for the 83xx and 6400M switches? (For example how many VRFs you can and how many routes in those)
Highlighted
MVP Guru Elite
if remenber, it is 64 VRF max
PowerArubaSW: Powershell Module to use Aruba Switch API for Vlan, VlanPorts, LACP, LLDP... More info
PowerArubaCP: Powershell Module to use ClearPass API (create NAD, Guest...) More info
PowerArubaCX: Powershell Module to use ArubaCX API (get interface/vlan/ports info)
PowerArubaIAP: Powershell Module to use Aruba Instant AP
PowerArubaMC: Powershell Module to use Mobility Controller / Master
ACMP 6.4 / ACMX #107 / ACCP 6.5 / ACSP
Highlighted
MVP Guru
The number of supported routes is documented in the product DataSheet.
The number of supported VRFs has been increased over the past main releases for 8320/8325/8400.
For all products, it is now 64 VRFs.
The number of supported routes is given for all aggregated/configured VRFs (not per VRF).
Highlighted
We're running MPLS between our distribution switches in different buildings and at the DCs we have a lot more than 64 VRFs configured. With dynamic segmentation we could probably do with a bit less, but currently it seems that for our use case that VRF amount would limit us.
Highlighted
MVP Guru
This topic would deserve a separate thread as it is diverging from the initial subject of the current thread.
Highlighted
Yep probably 64 VRF limit is enough as there is no way to configure these centrally but just doing 'VRF-lite' type of stuff. And if you have more than 64 it's not really manageable :)
Still I think it's important to understand that there are limitations
Not sure how you would build your network with EVPN over VXLAN. Currently I think ArubaOS-CX only supports bridging, so if you're using FW as the GW you would have all the ARP entries on the FW and in a larger network that would be too much. Instead of doing IRB.
With MPLS PE's you can just have the local building PE act as a router and then just route that /23-/26 towards the rest of the network.
